NC35 keeps dieing when changing gears
Posted: Sat Jul 30, 2016 5:27 pm
by Mavirick
Hay all
Ok so problem started today after a few about a km of riding.
If she is idleing in neutral all good when i compress cluch all good as soon as i select gear 1st or 2nd it dies out if its not in neutral it doesnt start again... but if i select neutral starts immediately.
Why doesnt she die when i select gear... thought it was just cluch setting but its not
Kind regards
MAV
Sent from my SM-N910F using Tapatalk
Re: NC35 keeps dieing when changing gears
Posted: Sun Jul 31, 2016 4:22 am
by magg
Would check side stand switch. The light may be out but it also has to supply an earth signal to the ignition unit when the side stand is up otherwise the spark is stopped.
Posted: Sun Jul 31, 2016 8:49 am
by Mavirick
Magg that might be a problem see... my sidestand switch is broken but i must add its been broken for about 5 years now no issues but ill check it our quick thank you
Any other options on this
Posted: Sun Jul 31, 2016 12:33 pm
by magg
What do mean by broken, just the light not working, that is only the stand-down function of the switch and not the stand-up part of switch.
Posted: Sun Jul 31, 2016 4:55 pm
by Mavirick
No the piece that connects to the sidestand with the copper ring is physically broken in 2 and half is missing
