Nc30 fan not coming on
Posted: Sat Jun 11, 2016 5:41 am
by beastybikes
My nc30 fan aint kickin in at all.tested fan and thats fine and checked fan fuse so isn't that. Been told thermo swith could be a possibility anyone but dont fany paying £50 for one if aint that .can these be tested some how.any ideas cheers
Re: Nc30 fan not coming on
Posted: Sat Jun 11, 2016 6:18 am
by magg
At approx. 100deg C switch should close. Multimeter will tell you if it does.
Posted: Sat Jun 11, 2016 7:17 am
service book is in the downloads section, has details on testing fan switch.
if you take the one wire off it and ground it the fan should come on.. if it doesnt then you have a problem with fan / fuse rather as well as possible fan switch
Posted: Fri Jul 01, 2016 9:31 pm
by phil x
In more detail, remove the connector from thermo switch, with ign on, earth onto rad - does the fan come on? Now short to the engine/frame, does it come on?
Most fan issues are blown fuse as the fan has stuck from lack of use or a bad earth.
