Page 1 of 2
Front left header pipe is cold?
Posted: Sun May 29, 2016 4:51 pm
by Stockko
Just noticed the front left header pipe is cold, the others are all hot. Is this normal?
If not, any ideas what could be causing this?
Re: Front left header pipe is cold?
Posted: Sun May 29, 2016 5:16 pm
by sleepyboy
Hows the bike running ? I would have said its running on 3 only , but is that too obvious, check the plug and the spark off that cylinder
Posted: Sun May 29, 2016 6:40 pm
by Stockko
Running very badly: revs hanging at 3-2k, when I blip the throttle at idle the bike gasps for air and sometimes cuts out.
Tested the plug which is working as it should. I'm guessing it's only running on three, just need to figure out if it's a carb or engine issue.. Will get the cylinders compression tested next and make sure the carbs are all set perfectly.
Posted: Sun May 29, 2016 7:44 pm
by sleepyboy
Hi you could just drain a little fuel out of the Offending cylinder carb bowl , just to see if its getting fuel, then go from there
Posted: Sun May 29, 2016 8:59 pm
by Stockko
Thanks - just tied this carbs getting fuel, taken them off and everything in the carb is working as It should.
Posted: Sun May 29, 2016 9:08 pm
by sleepyboy
If you've taken them off are you going to clean them, because if you've got a spark at the plug and fuel in the bowl the only other thing is a blockage in the jets
Posted: Mon May 30, 2016 8:56 am
by Stockko
I have cleaned all the plugs and gaped them, jets are perfectly clean (brand new in fact)...
Posted: Mon May 30, 2016 8:59 am
by Icemaestro
The idle jets are new too? They are the usual suspects. That and or check float heights
Posted: Mon May 30, 2016 1:21 pm
by Stockko
hmmm the idle jets look fine to me. Havent checked the float heights yet, will give that a go next. Cheers
Posted: Mon May 30, 2016 2:57 pm
by richyrd5
Change the plugs over and see if it starts working in that cylinder.if it goes bad on other cylinder you know its plugs,if still the same then check plug cap,then carbs.....these motors are very spark plug sensitive,and one that sparks may not be ok to keep it running on that cylinder,,when were they last changed??
