NC35 Problems between 5000 and 6000 k rpm
Posted: Sat May 28, 2016 3:47 pm
by rvfpop
Hello I have problems between 5000 and 6000 rpm in my NC35 . The bike lose power in this rpm and is slow . Under 6000 and down 5000 is perfect . Is has spark plug news and air filter new . Carburetors are cleaned
Re: NC35 Problems between 5000 and 6000 k rpm
Posted: Sat May 28, 2016 6:59 pm
by Drunkn Munky
Does it rev fine past 6000 rpm? if not then check the orange and blue wire from the cdi is connected to 12v+
Posted: Sun May 29, 2016 9:20 am
by rvfpop
Hello , yes the bike is good up of 6000 rpm , and under 5000 is perfect I have problem betweenn 5000 and 6000
Posted: Sat Jun 04, 2016 5:18 pm
by vfrman
My money is on the carbs. Sounds like you are hitting the flat spot.
Posted: Wed Jul 27, 2016 2:18 am
by vfrman
I don't think so. When the reg/rec goes south, it usually cooks the battery. That makes the bike stop running altogether. The 5-6K flat spot is well documented on these bikes. Take a look at the carb guide sticky posts at the top of the V4 workshop section...
viewforum.php?f=24
