Parts interchangeably
Hi guya ive started the project on my cb400sf and a whole lot of research. Ive discussed the bike has alot of interchangeable parts with the cbr400 and whole lot of aftermarket parts on the market... Ive sent the bike away for some engine work but the rest of the work i will do by myself im located a site which has a list of parts that you can take from other hondas between the 92 ~ 98 model just the mechanical bits anr some engine internals....
Looking forward to getting her back nd getting her to tip top shape.
Here are some pics of the current condition
Ive sourced many aftermarket parts like mirrors handlebars grips chain tensioner reg/rec cdi some lights and speedo from a bandit performance chain nd sprocket aswell as brakes was thinking of getting new discs and exhauste system
Lemme know what else to add to the shopping list and some advice will be appreciated
Sent from my LG-V490 using Tapatalk
- Bike owned: '93 CB400 Super Four
Re: Parts interchangeably
Without looking at more details, your bike is definitely from 92-93. 94 has a different speedometer (with fuel gauge). 95-98 has a different crank case cover (right side).
For the most, parts should be cross-compatible and interchangeable between all the different generations of the NC31. If in doubt, consult the parts menu book (there's alot of them floating about on google). Its in Japanese, but it shouldn't stop you comparing the exploded diagram with the part numbers.
There are alot of Chinese-made aftermarket parts for the CB400 NC31. Should not be too difficult or expensive to restore the bike to looking as good as new. All the best
- Bike owned: cb400 sf
I was wandering if we can use a custom gauges for this bike? As I heard people said if we removed the original gauge you cant rev past 6k rpm and your bike will stutter is it true?
Not sure...
This is my beastie now...
Sent from my E5333 using Tapatalk
That honda badge looks cool, similar like the one from cb1300
- Bike owned: 1994 CB400SF, 2008 CBR600RR
Yes you can. Resistor mod to the Ignition module will fix the 6k stutter. And yes I do know I need to tidy things up.
https://scontent-syd1-1.xx.fbcdn.net/t3 ... 2760_o.jpg
Patch29.... could you kindly guide me reguarding luggage. I need something similar to what you have. Could you tell me what you have nd wer u got if from pls.
Thanks in advance
Sent from my SM-T550 using Tapatalk
Thanks in advance
Hi Lance, picked up some second hand Triumph Speed Triple saddle Bags, have also got a Ventura Rack on back...
I like your setup, looks tidy nd not too in the way.
Only prob is no passenger space but that should not b an issue, since we had a little accident my woman wont get on the bike.
Cheers mate, appriciate the reply, any complains about ur setup,or suggestions... would u do anything different if u wer to purchase luggage again?
