NC23 to 29 rear wheel
Posted: Tue Mar 29, 2016 11:18 am
by mattiec321
Hi guys
I'm converting my 23 track bike to accept the 29 17" rear.
i've got it all off and was initially told that the 23 sprocket carrier would slot in using the 23 cush rubbers.
The rubbers fit but the sprocket carrier doesn't.
Am i going wrong somewhere or do I have to find a 29 sprocket carrier?
Thanks in advance
Re: NC23 to 29 rear wheel
Posted: Sun Apr 03, 2016 10:11 pm
by tanuki
29-
Sprocket carrier
Cush drive
Brake hanger
You need all of these, you may also need the spacers but I'm not sure
Posted: Tue Apr 05, 2016 10:58 am
by CB1pod70
Yeah, you need the NC29 sprocket carrier & cush drive.
the NC23 caliper carrier can be used but there are 2 little dimples which need filing off to prevent them rubbing the disk.
The Nc29 spacers are also required and it helps if you skim 1mm of the spacer on the sprocket side otherwise fitting the wheel is a pig.
Give me a shout and I can chuck a spacer in the lathe for you.
Posted: Tue Apr 05, 2016 3:31 pm
by mattiec321
Brill cheers guys, I've located a set of rubbers and carrier care of Northermonkey....
The spacers I'm told were already machined down 1mm and the filed caliper bracket came as part of the deal....
Thanks all
Posted: Wed Apr 06, 2016 7:38 pm
by tanuki
Hopefully not the carrier he said I could have by PM.
Posted: Wed Apr 06, 2016 8:49 pm
by mattiec321
Ooo err... Maybe you should speak with him
Posted: Thu Apr 07, 2016 1:21 pm
by northernmonkey
Don't worry gents, I had 2 sprocket carriers
