VALVE STEM OIL SEALS
oiledaplug
Hi chaps,
Im having trouble locating a set of valve oil seals for Superfour/Cb-1. Ive ordered a set from hong kong via ebay, but after 4 weeks wait---- nothing. I,ll get a refund and buy elsewhere when i can locate some at a sensible price. Dave silver wants around £6.50 EACH. Cant find any others on ebay,apart from the hong kong ones, so hoping you chaps could point me in the right direction.
thanks, and merry xmas, JEZ
bludclot
- Bike owned: 98 R1, 95 CB1000, 92 CB400
Re: VALVE STEM OIL SEALS
you could try john oldfield in southampton. he's very clued up on parts and availability.
- Variablevalves suck
If you get desperate ive a mate that works for a bearing / seal company and he maybe able to help but would involve sending me a old seal.
Ive seals from a couple of Suzuki's so could compare them at the same time as alot of bikes use the same seal, usually 4.2mm or 4mm on the 4's.
oiledaplug
Thanks for the info.bludclot wrote:you could try john oldfield in southampton. he's very clued up on parts and availability.
jez
oiledaplug
Thanks for your reply----- I will contact you if i get completely stuck. I measure the valve stems at 3.7mm.Variablevalves suck wrote:If you get desperate ive a mate that works for a bearing / seal company and he maybe able to help but would involve sending me a old seal.
cheers, Jez
That is one thin valve.
Link to some from china.
http://www.aliexpress.com/item/16PCS-mo ... 653.vEtKfx
oiledaplug
Many thanks for that------ Ive ordered a set.Variablevalves suck wrote:That is one thin valve.
merry xmas, JEZ
