				Radiator Cap Dimensions/X-ref
				Posted: Fri Dec 04, 2015 12:23 am
				by SPOONDIDDLY
				G'day guys,
I'm looking to do an overhaul on my RVF's cooling system - inspecting, cleaning and replacing everything.
So I have started to stockpile bits for this and the one thing that I am unsure of is the radiator cap!
Does anybody know any aftermarket brand part numbers for radiator caps that will work?
Or the dimensions/specs for what is needed?
I would prefer to go aftermarket than OE as I work in automotive and can easily access parts locally
				Re: Radiator Cap Dimensions/X-ref
				Posted: Sat Dec 05, 2015 7:44 am
				by SPOONDIDDLY
				So nobody has an alternate part number or a spare cap that they could measure up?
If I have the correct measurements I can find a suitable part number and post the x-ref for all
				Posted: Tue Dec 08, 2015 10:19 am
				by SPOONDIDDLY
				So I take it that no NC30/35 owners have radiator caps?
				Posted: Tue Dec 08, 2015 12:19 pm
				by richyrd5
				Hi.i have a cap to hand.what do you need know chap?
				Posted: Sat Dec 12, 2015 8:19 am
				by SPOONDIDDLY
				Brilliant!
I guess I need to know:
- diameter of the main seal
- length from the top of the cap to bottom seal
- Inside diameter of the radiator cap (not including the toggles that hold it on)
- Distance between the toggles
- Pressure that the caps rated to (if it's printed on the top)
				Posted: Sun Dec 13, 2015 1:05 am
				by richyrd5
				As written:38mm
                     21mm
                     43mm
                     33mm
                     1.1.
Hope that helps..
				Posted: Sun Dec 13, 2015 1:06 am
				by SPOONDIDDLY
				Perfect! Thanks mate!
				Posted: Sun Dec 13, 2015 1:09 am
				by richyrd5
				Posted: Sun Dec 13, 2015 2:07 am
				by SPOONDIDDLY
				Just one more quick question mate - does it have a bayonet fitting or a screw fitting?
				Posted: Sun Dec 13, 2015 12:07 pm
				by richyrd5
				Bayonet..
