down but not out!
Posted: Mon Aug 31, 2015 2:47 am
Back after 11 years !
11 years ago I parked my 30 and life took over. Brought a gsxr750 99 and had (still do) all sorts of issues.. then the other day I noticed my 30 sitting there. She hadn't been moved at all for 11 years, so...
Pump up the tyres, cut the chain, remove all the calipers and she is rolling. Then removed the sump and rocker covers and suprised there is oil! And nothing has rusted up.
Removed the plugs and dropped in some 2 stoke oil (just incase) and got the battery from the land rover (1000cca!) And she turned over.
So what now?
Well she's had the block removed to find gum (best description I can give!) In the water galleries but the bores are okay. Checked the valves and they are sealed still from the lapping 13 years ago. The tank however... well think sieve! So after several attempts to remove the rust using caustic soda, spirits of salts, Doex-c and then electrolysis, all I need to do it weld up a few holes (electrolysis from a 15amp supply probably wasn't the best idea) and pour in por-15, paint the outside and job done on the tank front!
However. All this excitement of getting her back on the road might have found a stumbling block. Is it just me or is it to quote some one "it's like rocking horse poo with unicorn horn sprinkles on top" damn near impossible to actually get hold of a clutch cover that isn't battered to hell!?
It would appear that when honda built the 30 it was built to last.
Will be posting lots of questions as my knowledge has moved to land rover.. aka the 'mecc-a-no!' set
Mike
So what now?
Mike
