Page 1 of 2
Rvf 400 Front wheel alignment
Posted: Sun Jul 19, 2015 11:53 am
by DanCapper
Hello
I have just tried lining my front wheel up with the back using straight bars and it appears to far over to one side. It is central in the forks so could be theres a spacer missing out of the rear wheel? I am really stuck at the moment an wondered if anyone on here has any experiance or guidence they can offer?
Thanks, Dan
Re: Rvf 400 Front wheel alignment
Posted: Sun Jul 19, 2015 6:32 pm
by skinnydog0_0
Are you running standard rear wheel?
How much out is it?
Posted: Mon Jul 20, 2015 3:11 pm
by DanCapper
Im running a vfr rear wheel, its out by about 5mm. I think it could be the rear swing arm?
Posted: Mon Jul 20, 2015 4:00 pm
by Drunkn Munky
Right spacers in the swingarm? you havent put a VFR swingarm in too have you?
Posted: Tue Jul 21, 2015 11:42 am
by DanCapper
Its definatly a rvf swing arm but the spacer may be wrong. The front and rear wheel are parellel but the front is 5mm off centre when aligned with the rear. Has anyone got a size for the swing arm spacer?
Posted: Tue Jul 21, 2015 2:04 pm
by Drunkn Munky
You wont have VFR and RVF spacers mixed up as the spindle size is different. Is there a possibility the bike could be bent?
Unless fitted by a complete numpty its very hard to put the rear wheel components on wrong to make it off centre and if your saying the front is central in the forks then it can only be bent.
Posted: Tue Jul 21, 2015 3:19 pm
by DanCapper
The wheels are still parellel so it couldnt be bent. Ive had the bike for years an ridden it as is an not noticed. I recently had the forks done by maxton so came to line it all up an noticed. The rear hub is assemled correctly. Its wierd how its exactly 5mm out like a spacers missing or too short. Ive made new spacers for the swing arm and the sprocket to space it accordingly if all lines up then am tempted leave it
Posted: Tue Jul 21, 2015 4:02 pm
by skinnydog0_0
If nothing has changed then there is something wrong with the way ts gone back together
I wouldn't use made spacers as you could be riding a death trap.
Do you have the front calipers on?
If you haven't cashed it, it should be straight
Have you taken the swing arm out and tried reassembling it?
Posted: Tue Jul 21, 2015 4:12 pm
by DanCapper
Its all together correct. The calipers are on but i cant see how thats relevent? Its is straight because as i said if it wasnt the wheels wouldnt be parellel. Has anyone accuratly checked there bike that can confirm they line up perfectly? Im an engineer so making a couple of spacers isnt a problem. Ive tried everything with the swing arm but come to the conclusion all that could be wrong is either the central spacer between the two bearings or the spacer on the sprocket side.. Does anyone have correct measurements for these?
Posted: Tue Jul 21, 2015 4:20 pm
by Drunkn Munky
Not without taking a bike apart, do you not have the original spacers?
