vfr400 nc21 problem
Posted: Sun Jul 05, 2015 3:44 pm
by cjford23
Hi all new to forum so hi, just wondering if I can fit a nc24 engine to a nc21, and what's involved ive read that alls different is a sensor on engine, but looms different to accommodate it, mine has the crank sensor, but I cant find a running nc21 engine anywhere for the life off me, my piston is missing valve gone, barrel battered god know what previous owner done to it, I have bought as project so need know what's involved in the process of putting nc24 engine in ?? Cheers all
Re: vfr400 nc21 problem
Posted: Thu Sep 03, 2015 7:38 pm
by startline
Still want an nc21 engine, I have one
Posted: Fri Sep 04, 2015 11:12 am
by slavokMS
To install the motor from nc24, you need to install your crankshaft sensors nc21 and overrunning clutch assembly with nc21.
Posted: Fri Sep 04, 2015 11:20 am
slavokMS wrote:To install the motor from nc24, you need to install your crankshaft sensors nc21 and overrunning clutch assembly with nc21.
or just fit the NC24 wiring loom....
Posted: Fri Sep 04, 2015 11:25 am
by slavokMS
Yes you can! BUT! there is an old engine it is easier to remove the necessary parts and install the new NC24 ;)
Posted: Tue Sep 08, 2015 1:45 pm
timing is slightly different on nc24 though so perhaps its worth to put the nc24 ignition box?
not sure
Posted: Tue Sep 08, 2015 6:55 pm
by richyrd5
seems better to take up startlines offer and put the 21 motor in!!
