Not ran for a long time, and now leaks fuel?
Posted: Wed Jun 17, 2015 7:56 pm
Evening, firstly apologise for only getting back on here when I have a bloody problem!
Anyhow:
My bike has been stored for about 18 months, I ran the fuel dry before storing it by running it then turning the fuel tap off until it stopped. I assumed this would stop any gumming of the carbs. It had worked before.
Anyhow this evening i decided i'd start it up with the idea of getting it sorted, MOT'd, back on the road and enjoy some summer sunshine.
So I did the usual starting procedure, choke on and don't touch the throttle.
After a while it fired but didn't catch, it kept dying. I kept trying and with a bit of throttle managed to keep it running at about 5k, it sounded a bit limp and there was a lot of steam/smoke out of the exhaust which I sort of expected. However it still wouldn't idle and then I noticed a fairly large puddle of petrol all over the bloody garage floor.
I assume its probably one of the carb floats that's stuck.
Does that sound probable?
I removed the rear spark plugs to see if they were wet, they didn't seem too bad, I hope I haven't ruined the plugs as well.
Is it possible to check the floats with the carbs on the bike or is it a removal job?
If I remember last time a good few years ago when I had the carbs off it was a right saga getting them back on again.
Any thoughts/advice welcome.
Ta
Anyhow:
Ta
