Page 1 of 2
GSX1000 suspension upgrade on zxr400 L9
Posted: Fri Jun 12, 2015 11:02 pm
by thegeekuk
So after my first Project bike cbr400rr got rear ended only a couple of weeks ago after being on the road for three weeks I picked up a Zxr400 for a great price. So it's a bigger bike although its ride height feels lower. I have obtained a gsxr1000 ohlns shock on the bay for a good price but I wondered if anyone else had found a way to raise the bikes height more. My cbr had the 600rr rear shock conversion so the ride height was great for my 5'10 90kg frame. But I want to raise the zxr to the same height and make it more stable for my.weight. I have brought the rear shock pre load up to 4 already. But thought there maybe something else I could do to raise the bike.
Also I wanted to change the rear sproket to get more acceleration. Wondered what ratios people had had some luck with.
Thanks M
Re: GSX1000 suspension upgrade on zxr400 L9
Posted: Mon Feb 08, 2016 9:37 am
by richyrd5
When you say you brought rear shock preload upto 4 do you mean the adjuster at the bottom of shock?as this is rebound adjuster(controls how fast the shock returns after being compressed)preload is adjusted by the locking rings at top of shock body(threads)adjusting the 4 stage rebound won't raise/lower the bike!!
Posted: Mon Feb 08, 2016 11:24 am
by Drunkn Munky
Id imagine when he said he had upped the rear shock preload by 4 he meant the preload and not comp or rebound, not entirely sure why you thought he was adjusting the rebound
Regardless more preload wont make it sit higher but will reduce sag when sat on. Im not sure how the ZXR is setup but spacers under the shock mounts or shorter tie arms will raise the height a bit. Does the GSXR shock fit straight in then? spring rates and length roughly the same?
Posted: Mon Feb 08, 2016 10:05 pm
by richyrd5
Ah.now I see he meant the gsxr ohlins shock he's put to 4..i seen zxr and mentioned the rebound as its numbered 1-4....
..but as said preload won't raise/lower ride height....would like to know more about gsxr shock onto zxr 400 as well chap..any details.
Posted: Tue Feb 09, 2016 9:32 am
by hunter
We have a GSXR1000 Maxton in our 400L.
Posted: Tue Feb 09, 2016 10:58 am
by richyrd5
Cheers john..will pick your brains when your back and find out what needs doing.cheers
Posted: Tue Feb 09, 2016 3:15 pm
by hunter
I'm back rich,
But the bike isn't,Will be picking them up sat.
Posted: Tue Feb 09, 2016 4:32 pm
by richyrd5
Ah right...had a good time chap?
...twirling spanners weren't you...did ya get to have a go round the track
Posted: Tue Feb 09, 2016 9:16 pm
by hunter
Yep had a great time,Was kept bizzy with two bikes.
No didn't get a ride myself having shoulder issues, waiting for surgery.
Posted: Tue Feb 09, 2016 9:17 pm
by hunter
viewtopic.php?f=10&t=51418&start=20
