Air leak screeching sound?
Posted: Sat Nov 15, 2008 1:06 pm
I took off my carbs (NC30) to tweak the pilot screws after installing a carbon airbox.
The front right carb rubber was slightly chewed, so obviously I didn't get it perfect last time (about a year ago). At that time I installed all new rubbers.
Anyway, I got them back on, bike started up but didn't run well at all and had an obvious-sounding hissing air leak. Checked the carbs and I hadn't fully seated them. The best I can manage now is 'very nearly' seated, but the front right rubber is a little deformed and the ring-clamp won't grip it properly. Maybe I can take a photo, will try tomorrow.
So when I try to start the bike, I get an intermittent screeching kind of sound which doesn't sound metallic at all, but could hopefully be explained like somebody playing 'comb & tissue-paper' with rubber and ali if you get my meaning. I'm really hoping this is what the noise is, just air forcing past the edge of the rubber. Because if it isn't I will be a bit worried...
Has anyone else heard a noise like this? Was it an airleak? I should try to count how many cranks in between screeches to narrow it down...
