idling at 4000?
Posted: Tue Apr 07, 2015 6:26 pm
by dougie conacher
Hi there
just finished putting the carbs back together,finally got it going after lots of cranking and it decides to tick over at 4000,checked the choke and slides and there not sticking what should i try next.i dont want to take the carbs off if can avoid it. i strippedthe carbs to changed the jets and inlet rubbers.
thanks in advance dougie
Re: idling at 4000?
Posted: Tue Apr 07, 2015 8:07 pm
by arsey30
Make sure there is free play in the throttle cable, there is an adjuster the twist grip end of the cable.
Back off the idle screw.
Air may be drawn in past one rubber, so remove each plug lead in turn to see if revs drop off the same for each one removed.
Re: idling at 4000?
Posted: Tue Apr 07, 2015 11:15 pm
by watafu
Spray something flammable around the inlet rubbers, see if the revs increase. Its pretty easy to have something not seated right and torqued down properly in that area, annoying aswell T_T Otherwise, reset your idle by checking the height its pushing the part that the throttle cables pull on, pull it all the way back so its not acting on it, then put it in a couple of turns and fire her up with a little choke. See where that lands you.
Good luck, just gotta persevere with these bikes >_<
Re: idling at 4000?
Posted: Wed Apr 08, 2015 10:49 am
with the airbox off you can lift up the vaccumn slides to see the butterflies below, they should be closed, if they are open then adjust the idle speed down / check for snagged throttle cables.
if you have just one buttefly open more than the rest your carbs are somehow really off balance.
if the butterflies are cloesd and you still have super high idle you have an airleak on the rubbers
Re: idling at 4000?
Posted: Wed Apr 08, 2015 1:10 pm
by dougie conacher
thanks looks like a airleak just didnt think it would rev that high due to a leak
cheers dougie.
Re: idling at 4000?
Posted: Wed Apr 08, 2015 5:03 pm
dougie conacher wrote:thanks looks like a airleak just didnt think it would rev that high due to a leak
cheers dougie.
srpay a load of wd40 around the carb rubbers while its running and see if you cna stop it revving
