changing speedo from kph to mph
- One Hit Wonder
- Bike owned: 1988 kawasaki ZX 400 G
hi can anyone please help me ?
I have an old ZX 400g which is in kph and I want/have changed it to zxr 400 mph one , easy enough . now the question :- the old speedo ( KPH ) has the three restrictor wires ( connector) on the dial ( same as zxr restricted type ) well the mph ( ZXR mph one ) doesn't have the wires on it , so do I have to bridge the wires on the main harness where it would have plugged in or what do I do ( three wire block connector ) ?
I have also got the British ecu ( blue label with M ) which I have read on another form is the British derestricted version ." please someone must know" . I know how to derestrict the kph one ( remove plastic inside dial its self )
Re: changing speedo from kph to mph
Yup.i need some info on doing this as well...did you find out after chap??
You have to either do resistor mod or get cable converter...i think the resistor mod is easiest for you as you have mph clock...10k 1 watt resistor on pink wire then earth it..easy!!
