35 swingarm on 30
Posted: Sun Feb 22, 2015 5:25 pm
by richyrd5
Is it worth the hassle?i can get a polished one and do like the brembo caliper conversion...also whats the crack with putting a 35 sprocket carrier on a 30!??thanks
Re: 35 swingarm on 30
Posted: Sun Feb 22, 2015 5:59 pm
by skinnydog0_0
They are not interchangable - the 30 is slightly narrower across the pivot than the 35.
Sprocket carriers are okay to swap though.
Posted: Sun Feb 22, 2015 8:46 pm
by hunter
You could probably fit one using spacers.
Posted: Mon Feb 23, 2015 10:50 am
202 and 208 springs to mind but the rvf arm is narrower.
Posted: Mon Feb 23, 2015 11:25 am
by speedy231278
Here you go....
Posted: Mon Feb 23, 2015 2:47 pm
by richyrd5
ah cheers chaps for that,not really worth the hassle just for a caliper conversion..although it wouldnt be hard to do.as john said 2 spacers!,what is better about 35 sprocket carrier than a 30 one jeff?
Posted: Mon Feb 23, 2015 4:10 pm
by skinnydog0_0
Yer i got the dims back to front.
I have no idea if the 35 sprocket carrier is better than the 30 i think they are the same other than the 30's one is black and the 35's is gold.
I am sure i'll be corrected if there is a difference :)
They have different part numbers but i have a 30 one on my 35 swingarm and hub and it seems to fit bang on.
Posted: Mon Feb 23, 2015 9:26 pm
by richyrd5
Cheers chap.that about figures.its gold!!.wondered what was different!!thanks
