Nc30 crankcase bolt torques
Posted: Thu Nov 06, 2014 9:22 am
by Tim400GB
Can anyone tell or show me for certain what the torque settings are for the crank bolts and the rest of the crankcase bolts are?
There are 6mm, 8mm & 10mm bolts in the upper and lower cases.
I had a look through the workshop manual on here but they're not jumping out on me.
Re: Nc30 crankcase bolt torques
Posted: Thu Nov 06, 2014 10:51 am
by hunter
The Haynes manual says,Case bolts 6mm. 12Nm.
8mm 23Nm.
10mm 40Nm.
Posted: Thu Nov 06, 2014 11:10 am
would trust the haynes book they are always wrong on specs...
If they arnt listed with a special toruqe in the Torque section (1-14) then refer to the torque settings at the start of the section, it lists nominal torque values for all fastners on the bike that do no have a specific torque.
these are from the nc30 manual, they are lower than the haynes manual, i do remember seeing broken sump bolts before, maybe from the hanyes.
Posted: Thu Nov 06, 2014 11:11 am
by speedy231278
Pages 1-14 and 1-15 of the service book should help.
Posted: Thu Nov 06, 2014 12:34 pm
by Tim400GB
cheers chaps got it sussed
6mm - 12Nm
8mm - 23Nm
10mm - 40Nm
Posted: Thu Nov 06, 2014 2:42 pm
by hunter
Haynes was right for once.
