NC35 Steering head bearings
Posted: Sun Oct 12, 2014 9:22 pm
Is there a design flaw in the locking mechanism on the steering head bearings?
Mine were loose - took it back to the dealer (still under warranty) - got them retightened...came loose again.
Had a look-see myself today (with the help of the Haynes-book-of-lies) - and the issue is, well - the procedure is to adjust the bottom nut till the bearings are at the correct tension, then hand tighten the locking nut and then tighten the locking nut further until the locking washer (a washer between the two nuts - it has lugs that are bent up and down into the cut-aways of the two nuts) has a tab aligned with the locking nut - and bend the tab into place. This will stop the damn thing coming undone.
However, this *doesn't* work - if you when, hand tightened it is exactly aligned so you can bend a tab up now...there isn't enough "squish" in the locking washer to rotate the locking nut another 90 degrees to align with the next tab....
What I did today was fashion an extra washer between the two nuts (above the locking-tab-washer) so that the locking nut was in a slightly different location - and could be tightened properly before the locking tab got put into place.
Anyone else come across this?
Or even understand what I mean.
