Page 1 of 2
NC35 shock
Posted: Fri Aug 29, 2014 12:18 pm
by Foxy400
Advice needed. The shock on my bike has covered 25,000 miles. Can this unit be rebuilt or should I junk it? If it can be rebuilt can anyone suggest someone who could do it and an idea of cost. Cheers.
Re: NC35 shock
Posted: Fri Aug 29, 2014 3:14 pm
by Drunkn Munky
Bin it your be better off with a late NC30 shock if on a budget
Re: NC35 shock
Posted: Fri Aug 29, 2014 5:45 pm
by Foxy400
Thanks, that's useful to know. Why is the NC30 shock better? Is it a straight swop? Should the NC30 shock be rebuilt or fitted as it is? (bearing in mind it will have done a fair few miles).
Re: NC35 shock
Posted: Fri Aug 29, 2014 5:50 pm
by richyrd5
Straight swap, get the later one with remote resiviour, and a rebuild would be a good idea!
Re: NC35 shock
Posted: Fri Aug 29, 2014 7:44 pm
by Drunkn Munky
The late NC30 shock has a remote res and some basic adjustability, the nc35 shock is just crap and non adjustable.
Re: NC35 shock
Posted: Fri Aug 29, 2014 8:29 pm
by CRM
Drunkn Munky wrote:The late NC30 shock has a remote res and some basic adjustability, the nc35 shock is just crap and non adjustable.
just like the forks too.
NC35 was certainly no "upgrade" apart from in style depending on which way you look at it i guess.
Re: NC35 shock
Posted: Fri Aug 29, 2014 8:52 pm
by richyrd5
CRM wrote:Drunkn Munky wrote:The late NC30 shock has a remote res and some basic adjustability, the nc35 shock is just crap and non adjustable.
Ohhh, you rotter!
, I thought they were a bit better, but no huh??
Re: NC35 shock
Posted: Fri Aug 29, 2014 9:30 pm
by Drunkn Munky
Nope internally the same
Re: NC35 shock
Posted: Sat Aug 30, 2014 9:36 am
by Foxy400
Right, it looks like I'm in the market for a late NC30 shock, with remote adjuster. Over to Parts Wanted...
Re: NC35 shock
Posted: Wed Sep 03, 2014 11:10 pm
by newtothis
"the nc35 shock is just crap and non adjustable"
Pardon my ignorance but what does the damping valve adjuster do then? Through a link posted by VFRhooligan I found this on Honda's website
To me it appears to show the range of damping force vs rate of movement at different settings. Also that the RVF shock has substantially more resistance than the VFR one in both bump and rebound.
Thoughts anyone?
Could anyone who can read japanese translate the axis labels?
EDIT - at work I have access to a tensile/compression test machine which can apply up to a ton of load. As and when I've got my stock shock off I'll run some tests on it and see what the performance is like. If anyone has a spare 30/35 shock kicking about that they could lend me I could do some comparison tests.
