nc29 running issues
Posted: Fri Aug 22, 2014 8:10 pm
im fixing up a cbr for my brother to race at thruxton in october but having a bit of a nightmare with it running.
-I have cleaned the carbs, float bowls were clean when i took them apart
-running standard jetting and set up
-new plugs
-nipped 5mm off each ht lead so fresh lead showing
-new fuel filter
It starts and idles ok, sometimes it can get a little lumpy idling but its intermittent. sometimes when riding it will pull nicely up to 9.5k then just bog and feel really flat, as if its dropping a cylinder. sometimes it will pull through but it will really struggle and lurch as if its cutting in and out of 4 to 3 cylinders.
Now today i rode it, it was riding as above for first half an hour, but then it started pulling clean through if you accelerated from low revs.
occasionally it will drop to 3 cylinders at very low riding speeds then pick up 4 at about 4/5k revs
Any ideas peeps
-new plugs
-new fuel filter
Any ideas peeps
