Replacing break light bulb on N30
crookzy1
One of the break lights is dimmer than the other. I notice there are different bulb types, which one do I need?
Also, looks like it's just a case of getting to the light, then popping the old bulb out and replacing with new one - is this so?
Thanks in advance mechanics.
Re: Replacing break light bulb on N30
take the faulty lamp out - it twists out the back of the lights - and take it to the shops and get another.
Simples./
Simples./
crookzy1
Good point :) Thanks!CMSMJ1 wrote:take the faulty lamp out - it twists out the back of the lights - and take it to the shops and get another.
Simples./
If you dont say what bulbs you have then its pretty impossible to say whcih, perhaps neither.crookzy1 wrote:One of the break lights is dimmer than the other. I notice there are different bulb types, which one do I need?
you can get a copy of the factory service manual from the downloads section, if you look in there it will tell you all the bulbs you need
crookzy1
Issue wasn't the bulb..turned out one of the wires was loose. Sorted now!
