gk76a carb removal demo
Posted: Sat Aug 02, 2014 3:23 am
by glimmer
being non mechanical it has taken me about four months to get the confidence to remove my carbs. i couldn't find a specific youtube clip+ i needed an idiots guide that explained the obvious....
So i made a clip when i took mine out.
forgive the poor terminology and less than professional capture.
https://www.youtube.com/watch?v=Mfui0fPsAqc
happy fettling.
glimmer.
and i forgot to mention the o ring at the bottom of the slide...
Re: gk76a carb removal demo
Posted: Tue Aug 26, 2014 11:31 am
by vic6169
HI Glimmer
Great video mate.
I stripped mine yesterday and then looked at your video.
My main jet tubes are also bent? Strange!!
Where did you get them from??
Vic
Posted: Tue Aug 26, 2014 3:59 pm
by SevenThreeSeven
Very good video, thanks for putting in the effort.
Those Mikunis are the most fiendishly complex carbs I've ever seen or worked on in my entire life, either car or motorcycle (and I've only got the version that was used on the Bandit400, which are a bit simpler than the GSXR version).
I believe they (the version used on the GSXR) represent the absolute zenith of production motorcycle performance carburetor development, when they are properly fettled and adjusted that is. The problem, as you well know, is keeping them healthy and happy.
I noticed that you used the word "Phillips" a couple of times when referring to your screwdriver. You should never use Phillips-type screwdrivers on Mikuni carbs. You need a set of JIS drivers (Japanese Industrial Standard) because they have a unique bit profile. (JIS screw heads can be identified by the little dot or divot in the crux of the head).
Keep up the good work. I'm looking forward to seeing more of your bike.
Greg
Posted: Wed Aug 27, 2014 3:11 pm
by vic6169
Thanks Greg
Its not my video mate.
I only watched it.
The video is from Glimmer?
I wanted to know where he got his main jet tubes from as mine are bent also?
Regards
Vic
Posted: Thu Aug 28, 2014 7:37 am
by glimmer
737, thanks for the jis info. i had read that that was what the head of the screw was. but being impatient i managed to get them undone with a hammer and drill bit tapped into the side, followed by a phillips. As a result the screws will need replacing and i retain my title as bodge master! ill probably replace them with hex head.
i live in NZ and bought the replacement jets from
http://www.motozone.co.nz/contact.aspx
joey was patient and helpful. they cost about $28 each though.
this place in the uk could also get them and posts international.
http://www.wemoto.com/bikes/suzuki/gsxr ... 76a/90-94/
my jets arrived today, so i replaced them and put my bike back together.
t.b.h. i don't think replacing them was necessary. but it made me feel better.... Shiny! and straight.
i took it for a test run after calibration. and it ran like shit. then i realized i'd left the vacuum caps of the carbs. Doh!!
So, tomorrow is the day...
