NC30 rearsets for taller rider
Posted: Fri Jun 20, 2014 10:20 am
by mark247
Hi all. I've recently purchased an NC30 with factory rearsets. I'm a reasonably tall guy and I understand a small bike such as an nc30 is never going to be super comfortable but I believe if I had some better(lower?) rearsets things would be that bit better. Does anyone have any suggestions on rearsets or spacers which are available which would give me a bit more leg room? I have previously owned an nc30 with tyga rearsets but it has been so long I cant remember if they were an improvement or not. Any suggestions would be excellent. Thanks in advance.
Re: NC30 rearsets for taller rider
Posted: Fri Jun 20, 2014 10:32 am
by mattUKNC
I think you'll find most aftermarket sets raise the peg position, not lower it. SES produce a 'standard' height replacement and also higher ones. You might be able to get someone to knock up some brackets and as long as you're not trying to get your knee down, you should be ok. :up:
Posted: Fri Jun 20, 2014 12:59 pm
by Speedy
Some time ago, there was talk of CBR600 OE rearsets fitting the NC but being lower than the NC's OE ones...
Maybe even other Honda models of the era have sets that fit the NC, but I guess the best way to be sure is to go to a breakers and check with any sets they got.
