NC30 speedo bulb holders
Posted: Fri May 02, 2014 9:06 pm
by jamie125
Are the bulb holders for the speedo lights still available in any form? Either from honda or an aftermarket item.
Re: NC30 speedo bulb holders
Posted: Sat May 03, 2014 1:09 am
bulb holders?
The little rubber bung things are part of the loom I think. What happened
Posted: Sat May 03, 2014 12:39 pm
by jamie125
Yeah the little rubber bungs I'm after, my bulbs are very hit and miss, give them a little wiggle and they come back on, very annoying. Was wondering if its the bulbs not seating properly due to the rubber bits?
Posted: Sat May 03, 2014 2:04 pm
by Cammo
The metal contacts in the rubber holders are very fragile and can be bent out of alignment.
Try and bend them so they make better contact with the bulb, it's helped me in the past.
Posted: Sat May 03, 2014 8:41 pm
Cammo wrote:The metal contacts in the rubber holders are very fragile and can be bent out of alignment.
yes this.
use a small watch type screwdriver, or a nedle etc.
the bulb holders inside have 4 prongs, two for eah side of the bulb, bend them in so they are almost touching and then push the bub in, it will be a nice snug fit and should work fine then, becareful you dont bend the tabs when insterting the bulb after tightening them up., the bulb should force them apart not squash them.
also make sure your using right size bulbs and theres no trouble with them
