Front brakes binding
Posted: Sat Apr 26, 2014 8:40 pm
Hey,
In the process of getting the bike to an MOT ready state. Last year it got an advisory for binding brakes, they've always been that way. Anyway, got the front wheel in the air, took the callipers off and:
- Replaced all dust seals
- Replaced all piston seals
- Replaced half-calliper O rings
- Cleaned out all the gunky shit (there was loads of grey sludge behind the pistons and inside calliper passageways)
- Used a dremel to polish each piston - all had loads of carbon-like build up on the first few mm - I got nearly all of them looking really nice, a few had some pitting but nothing major
- Drained all old brake fluid
Now, put the wheel back on, fitted callipers and spent about 1 hour straight bleeding the fucking things. Took absolutely forever to get any pressure anywhere, had to bleed top banjo bolt and both callipers about 30 times each. Put it all back together. Binding exactly the fudging same as before!. I'm at a bit of a loss, the callipers were in a fairly bad state beforehand, now they're freshened up, cleaned, new seals, new fluid and yet still they bind.
What else could it possibly be? I'm thinking tomorrow I'll try and lower the amount of fluid in the M/C see if that makes it any different but I'm getting towards the end of my tether with these brakes! The back one barely works and the front ones never stop working!
