2TK EXUP control unit - repair
roland jones
- Bike owned: FZR400 2TK FZR400RR SP FZR600R
Has anyone ever had their EXUP control unit repaired? (It sits under the EXUP pulley, in front of the rear light). The one on my 2TK only works when held tightly in my hand so there appears to be a broken circuit on the board. If anyone knows of a firm that can repair these units, please let me know. Is BDK worth a try?
Alternatively, are there any 2TK owner on the forum with a spare working unit that I could buy?
The part number is 2TK 85830 00 - I don't know if the 3EN models used this unit or had their own specific 3EN unit - perhaps someone can confirm this point also as it would help me broaden my search.
Thanks very much
Thanks very much
willandrip
Re: 2TK EXUP control unit - repair
3EN2 servo is 3FH-85850-00 so must differ in some way.
Used on the USA models so might be able to find one on ebay.com ... ???
Or look for somebody breaking a 2tk over here
willandrip
The SAC/SUC Usa models use the 3FH- unit
The 2TK unit appears model specific.
This may be more down to the casing fixing position, on its "back" at the very rear of the subframe on the 2TK;
as opposed to "upright" on the side of the 3 EN series/ SUC-SAC models..
The Exup servos are often stripped to replace the plastic operating gears ; so perhaps this option should be investigated to ascertain if a repair/replacement of the circuitry is possible.
Would it be possible to remount a 3EN series servo in the relevant position ?
Above is a YZF 750 unit fitted to the 2TK subframe.
- laminator
- Bike owned: 2tk,NC30, YB7
OOps - I googled the part no in OP ... which turns out to be the CDIwillandrip wrote:The SAC/SUC Usa models use the 3FH- unit
as opposed to "upright" on the side of the 3 EN series/ SUC-SAC models...
If you can't find a replacement then have a look at using the 3en part (or similar) to rebuild yours. If you try to use a 3en servo in a new position you could need the cables as well which would be harder to find.
roland jones
Thanks all for your responses so far. It is the ECU (which sits beneath the servo on the 2TK) rather than the servo itself which needs repair. I phoned Brock at BDK today and he thinks it should be repairable so I will send it off and await his verdict.
I have done some more investigations and the ECU's 2TK part number is, according to the CMS NL website, the same as 3EN models so it looks as if a 3EN ECU will work. Happy to open negotiations on a spare unit if anyone has one!
£en cdi's aren't to much money on the bay but they have a Jap speed restriction which needs a signal from the speedo (which your speedo won't have) so it will restrict you to 12,500rpm in all gears.
I seem to remember Kayla having a 2TK cdi but she may have sold it by now
- laminator
I don't have a spare but a quick google search found this in Ireland :-roland jones wrote:Thanks all for your responses so far. It is the ECU (which sits beneath the servo on the 2TK) rather than the servo itself which needs repair. I phoned Brock at BDK today and he thinks it should be repairable so I will send it off and await his verdict.
http://bikebreakers.ie/fzr-400-exup-2tk-cdi-p-601.html
(Never bought from them so can't comment on delivery, etc)
willandrip
The 3EN1 TCI is interchangeable with the 2TK unit; the 3EN2 is not and will not operate.
The cost of repair is well over that of replacement;2TK units often appear on the bay at circa £35 ish.
The part nos. are not the same.
Go to "racing a 3EN2" topic by Kayla on this forum ; there are pics and description of what does/doesn't work
Ignitor units on Fzr motorcycles are of the TCI type and if were referred to as such would save much confusion and timewasting !
