NC35 emulsion tubes
Posted: Thu Mar 06, 2014 2:57 pm
by sniff
Mixed up the tubes when cleaning, which set goes to rear bank?
My initial thought is top ones, with the lower hole, to rear cylinders, but....many thanks
Re: NC35 emulsion tubes
Posted: Thu Mar 06, 2014 9:20 pm
by watafu
If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
Posted: Thu Mar 06, 2014 10:48 pm
by Cammo
sniff wrote:Mixed up the tubes when cleaning, which set goes to rear bank?
Your thoughts are correct, the top 2 tubes in the pic are for the rear cylinders. :up:
watafu wrote:If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
That info applies to NC30's only, rvf parts are quite different.
Posted: Fri Mar 07, 2014 9:08 am
by sniff
many thanks...
