Electrical issue cutting engine out
Posted: Sun Feb 16, 2014 8:38 pm
by VFRRussell
I have recently rebuilt a NC30 grey import. I took her out for the first ride today and must have broken down about 5 times. When trying to indicate whilst moving, the bike just completely lost drive and conked out. The battery was also full when setting off and had discharged itself within about 5 miles meaning a bump start was the only option.
Any ideas??
Re: Electrical issue cutting engine out
Posted: Sun Feb 16, 2014 8:55 pm
by rcv4
my money is on the rectifier is allways a good starting point,also check the block connector to it.
Posted: Sun Feb 16, 2014 8:59 pm
by VFRRussell
thanks for the tips. Are these the common symptoms?
Posted: Sun Feb 16, 2014 9:35 pm
by bikemonkey
Haha no I don't think they are normal.
I'd be checking for a short to ground somewhere, maybe the indicator wiring seeing as it conked out while you were indicating?
Posted: Sun Feb 16, 2014 10:27 pm
reg rec failure is common...and it can take the battery and genny with it - so worth checking
