front brake compatibility
Hi, are the front callipers off earlier FZRs the same as the 3tj?
(mine came with Honda callipers and adapter plates)
Re: front brake compatibility
The earlier RD FZ600 or Genesis have similar spacing but they're 2 pot. I should have a pair of calipers somewhere with new seals etc
cheers, I meant the 4 pot ones that pop up on evilbay. They look similar but maybe there mounting centres and left-right spacing is incompatible?
3TJ calipers are different to all the other earlier bikes as far as I know.
Yes 3TJ calipers are just 3TJ calipers.
The calipers themselves are pretty good, they need to be clean and the disks need to be ok, but after that it's a pretty good system.
Yep very good calipers, I've got a set of R1 blue spots but haven't bothered using them as the standard ones are so good.
