High load miss at >7500rpm
Posted: Wed Jan 08, 2014 10:46 am
MY superfour has developed a weird problem since I have got it back on the road and I cant seem to figure it out. It pulls fine from 2500rpm at full throttle but as soon as you hit 7500 it just seems to stop dead. No idea whats going on.
Mods that have been done to it are as follows:
Danmoto Slip on and link pipe
105 Main jets (Too small still maybe?)
K&N Air filter
2.5 Turn Idle mixes
CDI Derestrict Resistor
CR9EH Spark plugs (One range colder)
16/37 Sprockets
Have put new plugs in it today and the problem still persists. It also has new lead ends and the problem only occurs when trying to access the higher part of the rev range at high throttle. Haven't tried lower throttle as If I am up in that part of the rev range then I will more then likely be using over 3/4 throttle anyway.
Any help would be greatly appreciated.
K&N Air filter
2.5 Turn Idle mixes
16/37 Sprockets
