quick NC35 electrical question
Posted: Fri Oct 24, 2008 2:12 am
by RVFHooligan
So, I charged and installed the new battery tonight. Slight malfunction with the signals. With the key on the front signals are lit up as running lights with no lights on in the back signals. Turning the indicator switch to either side results in a fast flash from the rear signal on that side, and the front signal on that side goes dark. Same thing for each side. Turn Signal Relay bad?
Re: quick NC35 electrical question
Posted: Fri Oct 24, 2008 2:21 am
by RVFHooligan
Never mind. Problem solved. For some odd reason each of the front signals had one wire pulled out of the connectors. Strange. Wonder what little monster could have been messing with the bike in the garage? Kids! :roll:
Posted: Fri Oct 24, 2008 7:57 am
by wullvfr
lol!!!!
usually when the flash rate is as fast its either a bulb thats blew or what happened to you.
it just means the one indicator is getting more power than it should hence the faster flash rate.
did you solve the problem with both front signals staying on?
william
