Carb screws
emto
Carb screws
Post by emto »
I went to strip my carbs to give them a cleaning but at least half of the screws on both the diaphram covers and bowl covers have ringed themselves. Any ideas what I should do next. I'd planned on replacing them anyway with stainless ones, M4 x 10, is this right?
Also, the screws on the carb rubbers don't look too healthy, anyone know what size these are?
Any help would be great.
superlite
Bike owned: TLS, LB80 x 2
Re: Carb screws
Post by superlite »
They tend to do that. They are very soft!
Yes, M4 x 10 mm will do the job. Washers on the float bowls are a very good idea.
An impact driver will do the job if you can brace the carbs well enough - carpet works well. Otherwise, liberal dosings of WD40 and give them a go - vice grips if they fit.
I couldn't source any cheap hex head screws in the correct size, so I use nickle plated phillips heads. They have survived hundreds of carb surgeries! But stainless would be preferred muchos!
As for the carb rubber screws: M5 x 25 mm
'Take it to the Back'
viper_biker
Re: Carb screws
Post by viper_biker »
In the past I've dremelled a straight line in then and undone it with a flat headed screwdriver.
Re: Carb screws
Philips #2 screwdriver fits them I believe.
I know a pozi will strip them as superlite said they are very soft.
Ebay Bolts
M4x10 STAINLESS ALLEN HEAD BUTTON BOLTS X 20 FREEPOST £2.15
emto
Re: Carb screws
Post by emto »
Thanks lads
katana
Re: Carb screws
Post by katana »
Hello
I'm being dense but are they the same bolts top and bottom?
If they are that would mean 36 bolts right?
Oh and how many carb rubber bolts are there?
superlite
Re: Carb screws
Post by superlite »
katana wrote:Hello
Top (slide cover) are 10 mm length. Bottom (float bowl) are 15 mm length with a spring washer - the washers make life a lot easier. 10 mm aren't long enough on the float bowls.
16 top and 12 bottom = 28 all up. It's handy to grab a bolt for the choke linkage too while you're at it - 10 mm with washer does the trick.
There are four carb rubbers which take two bolts each = 8 bolts.
katana
Re: Carb screws
Post by katana »
superlite wrote:
katana wrote:Hello
Thank you I'm poping over to a stainless steel place today so am trying to get all the bits I think i would need in one visit.
superlite
Re: Carb screws
Post by superlite »
katana wrote:Thank you I'm poping over to a stainless steel place today so am trying to get all the bits I think i would need in one visit.
That's the trick! I'm a big fan of blinged carbs! I don't like to say it (much), but my carbs are the best I've everseen! HRC'd and shiny to the max 8-)
Button head hexes are definitley a bonus if you can get them! I can't :cry:
RickOliver
Re: Carb screws
Post by RickOliver »
I supply ready made up stainless allen screw kits (with washers!) for both NC30 and NC35 carbs @ £7 a time.
Mail r.oliver(at)mtxnet.co.uk
Rick
