strange photo request
Posted: Wed Aug 14, 2013 9:39 pm
Hi guys and girls,
As the title suggests I am after some photos of the front end of an NC29. In particular the wiring loom around clocks and lights without the fairing on. Also, I would like a photo of standard bars with standard equipment on taken along side a tape measure.
The reason for this bizzar request is not for some weird perversion, I am trying to convert my old track bike back to standard spec. As it was a track bike all the lights and ignition were removed and bodged together, so some pictures of how the loom is threaded around this area would be a great help.
As for the photo of the bars and the tape measure, I'm embarrassed to say I'm confused. The clip ons and levers look stock, the switch gear is stock on the R/H bar, the L/H switch is from a CBR900 '99 and both switch gears are located correctly with the tabs in the correct holes. So why isn't there room for the throttle and grip on either bar? I'm about 20mm too short!
I don't believe they have been cut down as the ends are nicely chamfered and the holes are present and correct for the inner weight snap ring.
Cheers in advance.
Doug
Ps. I do have some track bits and pieces that need a good home.
Cheers in advance.
Doug
