NC30 engine presumed dead, but actually not!!
Posted: Wed Jul 24, 2013 12:34 pm
Right, whilst surfing Ebay one night i came across a nc30 motor that was about 20mins up the road from me and actually on my way to work, it was listed as seized but with a good gearbox and complete.
I thought this would serve 3 purposes perfectly them being -
A - i can take it in bits and teach myself how they are built etc, i can rebuild 2 stroke motors but i have never been inside a 4 stroke. As this engine was already broken i could not do any harm to it and ruin a complete motor with muppetry!
B - A good gearbox could very much come in handy for my track bike when/if 2nd goes crook on it
C - general spares, shims casings covers etc etc, all handy to have.
So i won it off eBay for less than 4 pints at my local!
Sure enough as I took it in bit it wouldn't turn over, only about half a turn, but as i began to take the heads off etc it became apparent that the motor was only refusing to turn over as one bore had a load of surface rust on the bore, I cleaned it out with a lollipop stick so as not to do any damage to the bore and some oil and eventually got it clear.
I can turn the engine over now by pushing the pistons seem ok, i have taken it completely to bits now and was wondering what to do with it next.
The bore that had the surface rust will be down on compression, now can i get it honed out get some new rings and put it back together. I know rings head gaskets and the rest will be more than a decent second hand motor, but it'd be for my trackbike. So was thinking i can clean up the inlets, lap the valves, plastiguage the shells, generally get it all refreshed and then have a motor that i know will be good for years to come with only valve clearances and oil?
Or will the damaged bore always be down on compression and make this a fruitless and pointless task. If so i will leave it in bits and use it as needed for spares.
