Carb Info
Posted: Tue Jul 09, 2013 4:05 am
Hi all,
I am putting the finishing touches on the Super 4 Carb kits.
In the attached diagram I read the parts as follows.
1/ It appears to have 2 fuel hoses (parts 30 and 31) and these attach to 2 fuel tees (part 4)
that are located between carbs 1-3 and 2 - 4.
2/ There are three large vacuum breather tubes, the centre one being a Tee (parts 3 and 5).
3/ There are two float bowl vent tees (part 2), again located between carbs 1-3 and 2 - 4.
Is this correct?
Finally is the choke plunger retaining nut a 10mm or 14mm hex?
cheers
Blair
Is this correct?
cheers
Blair
