Page 1 of 2
Quick action throttle
Posted: Mon Jul 08, 2013 9:15 am
by krisztian_andre
Re: Quick action throttle
Posted: Mon Jul 08, 2013 2:16 pm
by CRM
dunno, i know the NSR250 one is a direct swop. but if you get this let me know how you get on with it pls
Posted: Mon Jul 08, 2013 4:04 pm
by krisztian_andre
CRM wrote:dunno, i know the NSR250 one is a direct swop. but if you get this let me know how you get on with it pls
Will do. By the way what kind of a lubricant should I use for the throttle tube? It doesn't always return by itself.
Posted: Mon Jul 08, 2013 8:02 pm
by hardnutdvd
if it isnt returning, shouldnt that mean the cables might need adjusting rather than tubing lubricated?
Posted: Tue Jul 09, 2013 12:54 am
by Morespeedvicar
I've always used chain lube on cables, you can get cable oilers from ebay tho I've never tried one.
Posted: Mon Sep 02, 2013 12:56 pm
by krisztian_andre
Works fine (only fitted the the pull cable in the first notch), it could be a few mm-s longer. I used grease in the cable housing and chain lube on the handlebar. My handlebar was rusty and the old throttle tube was missing a piece at the end probably that's the reason it wouldn't return.
How do you install new grips? They won't go on and I don't want to use lube cause it will slip.
Posted: Mon Sep 02, 2013 6:45 pm
by marcus57
I use petrol to get new grips on hair spray
Posted: Mon Sep 02, 2013 6:58 pm
by krisztian_andre
marcus57 wrote:I use petrol to get new grips on hair spray
Hairspray I don't have, doesn't petrol degrade the rubber, how about isopropyl-alcohol?
Posted: Mon Sep 02, 2013 7:14 pm
by tigerclaw
Unexperienced question, doesn't a quick action throttle make it more tricky to control the throttle / grip when u are riding on the edge?
Posted: Tue Sep 03, 2013 4:09 am
by krisztian_andre
tigerclaw wrote:Unexperienced question, doesn't a quick action throttle make it more tricky to control the throttle / grip when u are riding on the edge?
Probably, but then there are trade-offs to everything plus my motor only makes 49hp so there's not much of an edge.
