Nc30 clutch/gearbox
Posted: Sun Jun 30, 2013 7:55 pm
by sp00ka
Iv noticed a few times lately riding the bike it's very cluky / stiff going from neutral to first when your about to pull away , and as the bike gets warm I find it a bit difficult find neutral ! Is this normal ?
Re: Nc30 clutch/gearbox
Posted: Sun Jun 30, 2013 7:58 pm
by Delboy
Sounds normal to me...usually if the choke is on you get a bigger 'clunk'...to find neutral try blipping the throttle when trying to find it...
Posted: Mon Jul 01, 2013 11:10 am
by Dynamohum
Oil and filter change if not recently done might help :?:
Too much free play on clutch cable :?:
Dot on gearchange knuckle aligned with gear change shaft dot helps sometimes .other than that it may just be a characteristic of your bike some are better than others in this respect.
Posted: Mon Jul 01, 2013 11:50 am
davethetrucker wrote:Oil and filter change if not recently done might help :?:
Yes.
Most often the clutch basket fingers get worn down by the clutch plates, this forms small grooves which stop the plates moving as much and can make shifting difficult.
