Stainless Steel Collar dimensions
Posted: Sun Jun 02, 2013 11:54 am
by KennonNC29
Hi would anyone have the dimensions for Stainless steel collars for the standard system I need to make some for my standard system and a standard cut system the collars on my standard system have just rusted clean off so would know what size to make the SS ones to.
Kennon
Re: Stainless Steel Collar dimensions
Posted: Mon Jun 03, 2013 1:58 am
by Morespeedvicar
Hi, i made the ones on mine about an inch long, cant remeber the id of the pipe tho. They dont need to be an exact length aslong as the front pipes sit in nicely that'll do.
Ian
Posted: Mon Jun 03, 2013 4:00 pm
KennonNC29 wrote:Hi would anyone have the dimensions for Stainless steel collars for the standard system I need to make some for my standard system and a standard cut system the collars on my standard system have just rusted clean off so would know what size to make the SS ones to.
Kennon
there was a near identical thread to this not long ago, I posted up pictures and measurements of my exhausts in it.
Do a search im sure you will find it.
I cant remember exactly off hand but if you make them 1.0mm or so smaller than stock you dont need to use the gaskets, clamps or put a compression split in it lke the orignal collars.
this is the way most aftermarket makes went for this joint (i put pics of that too.)
Posted: Tue Jun 04, 2013 12:15 am
by KennonNC29
Just tried to look through your past posts to find it with no avail will try again in the morning.
Kennon
Posted: Tue Jun 04, 2013 2:39 am
by Morespeedvicar
If you need to know the id for the collars just measure the front pipes od.....
Posted: Wed Jun 05, 2013 11:42 am
by rcv4
You need 1 1/2" tube 1.5 wall thickness i think i make them 35-38 long.
