running rich!!
Posted: Thu May 23, 2013 8:33 pm
by V4beermonster
hey all just dyno'd my "nail project" not run for 18-20 years but fully restored no but is running really rich. carbs have RO road needles, drilled sliders, carbs fully stripped,ultra sonically cleaned, rebuilt. ethos full system apart from rear manifold,running standard pilots, air filter, 120 mains in all 4. running nice power delivery is good no stummbles or hessitation. just rish advice please
Re: running rich!!
Posted: Thu May 23, 2013 8:38 pm
by Drunkn Munky
What washers do you have under the needles? RO needles are designed to be run either with no washers or just the standard 0.5 washers. I cant remember to be honest but im sure someone will be along shortly that will.
Re: running rich!!
Posted: Thu May 23, 2013 9:10 pm
by alexwitham
Dynojets or Keihin jets?
Re: running rich!!
Posted: Thu May 23, 2013 9:25 pm
by V4beermonster
Standard kein
Re: running rich!!
Posted: Fri May 24, 2013 12:15 pm
V4beermonster wrote:hey all just dyno'd my "nail project" not run for 18-20 years but fully restored no but is running really rich. carbs have RO road needles, drilled sliders, carbs fully stripped,ultra sonically cleaned, rebuilt. ethos full system apart from rear manifold,running standard pilots, air filter, 120 mains in all 4. running nice power delivery is good no stummbles or hessitation. just rish advice please
Well you said you have 120s and its going rich afer 7000 which is when its runnign on the main jets.
You can always drop the main jets down a size.
115 / 118.
But you'd be daft tuning to fuel air mix graph alone.. power curve and delivery is more important, even if its running a tad rich.
If it were my bike id try a 115/118 set in it and see which gave better rusults and leave it there.
how much hp is is puttin gout, I cant see from the graphc
Re: running rich!!
Posted: Fri May 24, 2013 1:44 pm
by speedy231278
Neosophist wrote:how much hp is is puttin gout, I cant see from the graphc
Looks like 55 and 56 from what I can see....
Re: running rich!!
Posted: Fri May 24, 2013 5:39 pm
by V4beermonster
Yeah 55.8 which I'm pleased with. When I built the carbs I put 115 in all 4 and it wouldn't rev up through the full range,was stuttering. Carbs are now all working ok will have a play tomorrow
Re: running rich!!
Posted: Sat May 25, 2013 5:14 am
V4beermonster wrote:Yeah 55.8 which I'm pleased with. When I built the carbs I put 115 in all 4 and it wouldn't rev up through the full range,was stuttering. Carbs are now all working ok will have a play tomorrow
Why are you using the same sized jets? the NC30 has staggared jets as stadnard.
Also make sure the emulsion tubes are in the right way (more holes in the rear).
Did you do anything to the carbs besides changing the jets from 115s?? i.e cleaning etc
Did you ride it? where exactly was the issues?
Re: running rich!!
Posted: Sat May 25, 2013 7:06 am
by V4beermonster
Carbs were in awful state just like the bike just stripped and ultrasonic cleaned, will drop in 115 118 today and see what it's doing, bike is running lovely and rich is always safe
