fzr 3en charging
				rrsp
- Bike owned: fzr600-,yzf750-,owo1,750
fzr 3en charging
does any body know what ohms reading there should be on the stator windings as bike isnt charging ? getting 0.6 ohms on all 3 wires is this correct ?
				Morespeedvicar
Re: fzr 3en charging
Hi, i can have a look at mine tomorow if i remember, it in bits so should be ok. Are there any shorts to ground on the three stator wires?
Its prob the reg/rec thats at fault, the one on mine went last year.
Ian
Ian
				rrsp
i put another regulator on from a breakers,was told it was tested ok.but still the same, not charging.ie battery does not charge when running. ?
				Clanky
- Bike owned: FZR 400 3EN1, FZR 600 3HE
Have a look through this thread on another forum:
http://www.fzrarchives.com/ipb/index.ph ... 52573&st=0
The guy with the user name DonTZ125 knows his stuff so look for his comments in particular.
				Morespeedvicar
Hi, really sorry about the delay, i'm getting about 0.7 ohms on mine to the three generator wires, i was gonna get the running disconected voltages for you aswell but not had time, i'll have a go tomorow if it stops raining.
Ian
Ian
				rrsp
fixed hairline crack in a fuse, kin nightmare !
