poor running at low revs, carb help
Posted: Tue Apr 09, 2013 10:11 pm
hello
so this was my post from a long time ago - 5 years :-O
viewtopic.php?f=24&t=4105
you'll be sorely disappointed to know that i just lived with it, and it got worse and worse (and i just revved it harder), so it got too much and i tore it down.
i am in the middle of cleaning the carbs, jets etc. etc., the tubes connecting the pairs of carbs (part 4 in the diag below) and loose and can flex (almost rotate) up and down, this is because the collars (parts 29) appear to be split.
http://www.cmsnl.com/honda-vfr400r3-199 ... ml#results
is this normal, will it affect my running, where would i be purchasing those collars, and how would i be fitting them?
you'll be pleased to hear that during it's winter off, it's been having new pads all round, new caliper seals, forks serviced, new rads, coolant flush, air/oil filters, extensive plastic welding on the fairings and i'm still looking for a new shock and ride height riser (shorter dogbones).
any help gratefully received
ta
fred
ta
fred
