NC30 rear shock spring?
Posted: Mon Apr 01, 2013 10:45 pm
by Spike16
Hey does anyone know what weight the stock rear shock spring is on an nc30?
Re: NC30 rear shock spring?
Posted: Tue Apr 02, 2013 2:02 pm
by iDemonix
I think I've got one at home in a box somewhere, if I remember then I'll see if I can dig it out and weigh it when I get home and let you know.
Posted: Tue Apr 02, 2013 10:49 pm
by Spike16
haha sorry not the physical weight lol the weight of the spring as in its force per displacement lol, its how you rate springs for a road/race bike its usually between 80-95kg lol
Posted: Wed Apr 03, 2013 6:57 am
by jetblack
1200 lb isnt it?
Posted: Wed Apr 03, 2013 7:43 am
by Drunkn Munky
Doubt it 7-800lbs as a rough guess
Posted: Wed Apr 03, 2013 1:20 pm
by iDemonix
Ah I thought you wanted physical weight for a race bike weight saving stats or something
I'm not sure on the rating, I've replaced mine with a new spring with a rating that I've already forgotten.
Posted: Thu Apr 04, 2013 12:27 am
by Spike16
any idea what the is in new money?
Posted: Thu Apr 04, 2013 7:51 am
by Drunkn Munky
12kg ish off the top of my head
Posted: Thu Apr 04, 2013 9:21 am
by speedy231278
Having had a search about, a lot of people say 850-900lbs/in. To translate to Kilos per mm you obviously need to convert pounds to kilos and inches to mm. So, 900lbs is approx 408.kg, and one mm is approx 0.04 inches. 408*0.04 gives 16.32kg/mm. To save faffing about, it's easier to work out the conversion factor. Using more precise figures, one pound per inch is 0.453592*0.03937=0.017858 kilos per mm. Call it 0.018. So, DM's 12kg spring would be 12/0.018 or 666.667 pounds, or alternatively an 800lb spring would be 800*0.018 or 14.4kg.
I'm pretty sure if you go to some of the serious suspension companies, you can choose your spring using the model, free length and rider weight.
Posted: Thu Apr 04, 2013 10:11 am
by Drunkn Munky
Here you go
