Clutch adjuster nut (handlebar end)
Posted: Fri Feb 15, 2013 9:25 pm
by iDemonix
For those following my plight, I got a lift home from Oxford to Nottingham to move my bike from my parents to my new house since the full rebuild. Four miles down the road, clutch cable snapped. 4 hours for recovery and I had to get a lift back to Oxford.
Two weeks later, I'm back, with a new clutch cable, and now this little wanker will NOT turn for love nor money:
Ignore the foam, it's soaking in silicone spray - I took ALL my tools and WD40 etc to Oxford, I'm stuck with screwdrivers and adjustable spanners... going to borrow some pliers tomorrow but it's well and truly welded.
Do these adjusters fit from any other bike? I'm presuming surely they must...
Cheers,
Dan
Re: Clutch adjuster nut (handlebar end)
Posted: Fri Feb 15, 2013 10:00 pm
by jetblack
I can pop over with some tool tomorrow aftenoon if it helps?
Posted: Fri Feb 15, 2013 10:04 pm
by iDemonix
Cheers matey, I'm going to my dad's workshop (carpenter) tomorrow to have a go, might give you a shout but we should have all the tools we need at the workshop - it'll either come off or be mullered!
To be honest I want a new one anyway as obviously this one is a fecking nightmare to adjust.
Posted: Fri Feb 15, 2013 10:09 pm
by jetblack
You might find that Pidcocks have one in stock, if you're lucky...?
Posted: Fri Feb 15, 2013 10:40 pm
by porndoguk
The cbr600f ones are cable clutched and the perch is the same, im pretty sure the cbr125 pre 2007 are the same also. Take it to honda counter a decent partsan worth his money will know which one will fit most hondas share parts along the lines.
Posted: Sat Feb 16, 2013 7:36 am
by iDemonix
Cheers :)
I think I'll have a bash at the workshop, if that fails, I'll probably strip the lever unit off the handlebars and take it to Honda Pidcocks - although getting the entire unit off the bars with no tools would be interesting.
Posted: Sat Feb 16, 2013 7:46 am
by porndoguk
Adjust the cable at the engine end? Its only a fine adjuster there for when the cable stretches. There is enough adjustment available to cover you.
Posted: Sat Feb 16, 2013 9:30 am
by thunderace
The adjusters are a standard part. Pretty much any Jap model adjuster should fit unless it's from some of the 125s, there's one or two about with smaller adjusters.
Posted: Sun Feb 17, 2013 7:39 pm
by RandomDan
Chuck it in the oven on a high temp for a little while and see if that frees it up.
Im sure they arnt hard to replace but your not going to let it beat you are you?!
