Tips for getting NC30 hub nut off?
Posted: Fri Feb 08, 2013 2:28 am
by StrayAlien
Hi all,
Last time I had to get a rear wheel hub nut of a VFR400 it seemed like a vast undertaking. It was like it had been put on by Dog Himself. Even with a 24 hour soak with WD40 on it. I needed to get someone to press on the rear brake lever so darn hard it was like I thought we'd break it. And I had my long socket handle put inside an old fork leg to help get some leverage, and they I practically had to swing on it. Man it was an effort.
(yes, I did lift out the little pressed-in bit on the nut that goes into the channel on the axle)
Now I have to do it again on a different bike.
So ... how do you guys get the hub nut off. Bike is NC30. Torque spec is 220 I think. And that is "darn" tight.
Re: Tips for getting NC30 hub nut off?
Posted: Fri Feb 08, 2013 6:46 am
by johnnie5
leave the bike on the ground
in gear
rear brake on
if all else fails , rattle gun
Posted: Fri Feb 08, 2013 7:57 am
by StrayAlien
Thanks, I've never felt great about using the gearbox to hold stuff. I know people that get the rear wheel nut off with the bike in gear and using the gearbox to stop the wheel rotating but I always thought it would be stressful for the gearbox.
but .. yet again the dark spectre of the Rattle Gun enters my life. Maybe I might just have to get one one day.
Posted: Fri Feb 08, 2013 8:04 am
by Drunkn Munky
They usually come off with someone on the bike holding both brakes on and then go at it with a big breaker bar but best way is a windy gun, takes 2 mins and without the need of help from someone else.
Posted: Fri Feb 08, 2013 7:47 pm
by Adderboy
I used a power bar inside a 5 ft scaffold pole :-) did it on my own by carefully locking on the rear brake using a broom handle wedged under the foot peg and tied in place, was dead chuffed when I shifted that !
