Page 1 of 2
Removing NC35 fork tops.
Posted: Tue Oct 30, 2012 1:20 pm
by racingt
Hi guys, want to swap springs. From the top of the forks, I've removed the circling, and the 22mm nut, and undone the 32mm nut, but it doesn't want to come apart!
Any ideas?
I have not resorted to brute force yet, seeking a thinking mans solution!
Re: Removing NC35 fork tops.
Posted: Tue Oct 30, 2012 1:36 pm
by speedy231278
Does the bolt in the bottom of the fork leg not have to be undone as well? I'm not sure if you can remove the spring or not with the damper rod still in place?
Posted: Tue Oct 30, 2012 7:00 pm
by racingt
perhaps.....
Haynes is not clear, but Rick thought I could change the springs by just undoing the top nuts.
Status is that the preload adjuster is removed, as well as the tripod adjuster, but the top bolt seems anchored in some way and will not come out.
Perhaps I have to remove the bolt at the bottom of the fork legs?
If so, it will have to wait a week.....
Posted: Tue Oct 30, 2012 7:41 pm
by porndoguk
racingt wrote:perhaps.....
Pull the forks out and bring them here 2 heads are better than one ;)
Posted: Tue Oct 30, 2012 7:43 pm
by speedy231278
Pics might help.... ;-)
Posted: Tue Oct 30, 2012 8:48 pm
by racingt
Rick will do!
Posted: Wed Oct 31, 2012 10:55 pm
by racingt
Sorted. Dropped forks out, discovered 6mm damper bolt in bottom, undid everything, swapped springs. No idea how to set oil level so poured in 450mill on each leg. No idea if I've mproved handling or not.
Springs swapped for RO kit, so I'm guessing it will work better....
Posted: Wed Oct 31, 2012 11:55 pm
by skinnydog0_0
I find it best to set the level by measurement from the top of the fork leg. Use a syringe with pipe cut to the desired length to set the height. Rick O will send one if you dont have one handy.
Posted: Thu Nov 01, 2012 1:53 pm
by racingt
Yep, thanks! So how do I do it?
Is the spring in at this point or not?
Sorry, totally unsure on this..
Posted: Thu Nov 01, 2012 1:58 pm
by speedy231278
IIRC, no spring, but fork leg fully compressed.
