Engine oil leak
Posted: Sat Oct 06, 2012 8:19 am
by revkid78
Re: Engine oil leak
Posted: Sat Oct 06, 2012 10:06 am
by bikemonkey
Sounds like your output drive shaft seal to me, crankcase splitter if I'm correct, big job.
Re: Engine oil leak
Posted: Sat Oct 06, 2012 10:31 am
by speedy231278
I think it is. I looked at doing this because I'm sure I've got something a little weepy in that area, and it would appear that the seal sits in a recess, and is sandwiched between the upper and lower engine cases. You might possibly the oil is coming from elsewhere, so it may be beneficial to take the front sprocket off, clean everything up and then run the engine to see if it's definitely coming out there. However, it may take a long time to build up until you notice it is there, and it might also be the case that unless the engine under load, the leak is minimal anyway.
If it really is leaking, I don't envy you!
Re: Engine oil leak
Posted: Sat Oct 06, 2012 8:56 pm
by lukemillar
Only other seal in that vicinity (apart from the output seal) is the clutch push rod seal, which doesn't require the cases splitting and is much cheaper/easier to replace. I'd be absolutely sure that it is the output seal before as it is a pretty big job!
