Page 1 of 2
FORK SEALS and other stuff
Posted: Fri Sep 07, 2012 5:45 pm
by Dowensy
Hi, anyone know of some rather strong forkseals, as my NC29 keeps destroying them and just had new stantions and a full clean but still enjoys destroying forkseals gone through 2 sets in 8 month and ive only done 3k miles anyone offer any advice?
Also is the HRC exhaust system better than the full yoshiumra system I'm using atm?
Finally I know they did an HRC airbox for the NC30 but did they do one for the NC29?
Re: FORK SEALS and other stuff
Posted: Fri Sep 07, 2012 6:14 pm
by Wozza
Are you not using Honda seals or doing too many wheelies?!
Posted: Fri Sep 07, 2012 6:17 pm
by Dowensy
First set where cheap ones new ones where Honda OEM parts and I don't wheelie this bike, but still keeps eating its forkseals anyone have any ideas?
Posted: Fri Sep 07, 2012 6:45 pm
by Wozza
You say the stantions are new so there is no rust/pitting whatsoever? And you're not damaging the seals when fitting?
Posted: Fri Sep 07, 2012 7:37 pm
by Yakama
Dowensy wrote:Finally I know they did an HRC airbox for the NC30 but did they do one for the NC29?
Yes there was an HRC airbox for the NC29, it requires some mds to fit though such as relocating the coils and dropping the rad slighlty for the air scoop. There was also two vairiations of HRC carb jet kit depending on what model of NC29 you have.
See scans of the HRC manuals here:
1992 Manual:
http://s254.photobucket.com/albums/hh88 ... %20Manual/
1994 manual can be found here:
http://www.400greybike.com/docs.htm
Posted: Sat Sep 08, 2012 12:25 am
by Dowensy
Brand new stantions and nope they worked fine for ages(forkseals), left the bike in the back garden for like 2 weeks and started leaking now :/ which is kinda annoying, also how hard is it to make the airbox fit?
Posted: Sat Sep 08, 2012 12:37 am
by Yakama
Not hard at all, its just its not simply a straight swap with the existing airbox
Posted: Sat Sep 08, 2012 1:15 am
by Dowensy
How much is the HRC goodness and do you have to make brackets for the coil packs or not? or is it literally unbolt them make HT leads longer and bolt them to something else? Also just ordered a ignitech CDI will i have to get that setup again?
Posted: Sat Sep 08, 2012 10:12 am
by Yakama
Contact Graeme France for the HRC airboxes he will sell you them and and provide you with all the fitting info etc. I only sell the HRC carb kits and they cost £100 see the link in my signature below for details
Posted: Sat Sep 08, 2012 4:03 pm
by Dowensy
Yakama if you click on your signature it says it no longer exists :/
