Page 1 of 2
vfr400 fork selector
Posted: Thu Aug 30, 2012 6:08 am
by rochie
hi all
would like to ask you all can i change a fork selector in the gear box with out removing the rear cylinders.
as 2nd gear feels like there a few teeth missing
Re: vfr400 fork selector
Posted: Thu Aug 30, 2012 7:28 am
by magg
To do any work inside the gearbox requires the cases to be split, i.e. removal of the engine and pretty much complete dis-assembly.
Posted: Thu Aug 30, 2012 6:39 pm
by scooble
I've replaced a selector fork in an NC30, unfortunaley, they are not a cassette gearbox, so its a complete engine out job and splitting of the cases. Be careful putting it back together though, as the selector forks have to fit in the right grooves when you lower one half onto the other, ideally its a two person job, with a torch and a long slim screw driver to ensure that they locate properly.
PS - would that be the black and red NC30 that went on ebay which 2nd gear wouldn't work?
Posted: Thu Aug 30, 2012 7:32 pm
by rochie
hi thanks for your replys
no it was not on the bay, the problem was a friend bought the bike but took it back cos as soon as you put into 2nd gear it felt like you wer on and of the throttle.
4 weeks later he got back in touch with my friend saying its fixed would he like to buy it back thats wer i stepprd in
i told him i knew the story behind it at that point he showed me a worn dog leg and said it took 4 weeks due to parts on order i asked he must of had to split the cases,, he said no that he went on to some forum and they said you can do it with out splitting the cases, at that point i jumped on nailed it in 2nd gear all seams fine ,,,,,,
50 mile later on way home in to a 2nd gear corner 13000 revs it done the same as it did at low revs but this time towards red line.
any idea anyone
Posted: Fri Aug 31, 2012 8:25 am
by scooble
does it jump out of gear then?
Posted: Fri Aug 31, 2012 12:02 pm
The clutch isnt slipping is it?
Posted: Fri Aug 31, 2012 5:32 pm
by scooble
its more likely to slip out of higher gears than lower gears.
Posted: Thu Sep 13, 2012 8:09 pm
by rochie
hi all
no it does not jump out of gear and ive also mstripped the clutch and changed the plates but it still is the same.
this only has this problem in 2nd gear
anybody have any idea ??????
Posted: Thu Sep 13, 2012 8:20 pm
by scooble
so, does it jump out of gear?
Posted: Thu Sep 13, 2012 8:30 pm
by rochie
hi no it does not jump out of gear
