Page 1 of 2
NC29 Dip Stick measurement.
Posted: Sat Jun 09, 2012 9:51 am
by RSVR
Can someone please measure the length of the NC29 dipstick indicator.
The reason for this seemingly daft question is:
I’ve just carried out an oil and filter change, and replenished with 3.4 Ltr’s of oil, but nothing registers on the D-Stick.
I need an accurate measurement to compare against the one currently installed.
Obviously it's on level ground.
Thanks in advance.
RSVR
Re: NC29 Dip Stick measurement.
Posted: Sat Jun 09, 2012 9:58 am
by nazzurro_19
May sound stupid but is it cause the oils new it looks see through you might be missing it
Posted: Sat Jun 09, 2012 10:11 am
by RSVR
No,
The Dip sticks dry!
Posted: Sat Jun 09, 2012 10:12 pm
by gullarm
doesnt the bike have to upright - not on side stand, as if you were sitting in it?
Posted: Sat Jun 09, 2012 10:38 pm
by nazzurro_19
It does yeah
Posted: Sun Jun 10, 2012 11:58 am
by RSVR
Chaps,
Obviously!
Can anyone please measure!!!
Posted: Sun Jun 10, 2012 2:45 pm
by Davez29
Ok, I was waiting to see if anyone else could do it for ya as I was only using my phone its a pain cutting and pasting...
This is from a post I answered on another site where someone posted a similar question.
Length of stick, taken from just under the plastic knob is 49mm. High mark 37mm and mid point is 44mm. All taken with a plastic ruler so is not perfect but should get you away. Go for 44mm ish. Level from the normal knob resting point.
I know flling with oil I always seem to add more than recommended.
dave
Posted: Sun Jun 10, 2012 3:17 pm
by gullarm
Ill second that.
Around 49mm from base of knob to end of dipstick.
From the bottom of the dipstick to the max oil marker looks around 10mm.
Took a photo but forget how to add them on here!
I wonder if its possible to push the dipstick into the plastic knob - so marking it shorter? Not on purpose of course, say if you dropped it.
Its also poss you have a different bikes dip stick, I suppose if the previous owner lost it they would bang any one on and worry about it later.
Posted: Sun Jun 10, 2012 4:35 pm
by Davez29
It should have a KT8 part number printed on top.
Posted: Sun Jun 10, 2012 5:11 pm
by RSVR
Chaps,
Many thanks I do appreciate it.
Well it's short...... from the plastic base to the tip is just 40mm, the high mark is at 26mm.
Anyone know the part number of the correct D-Stick.
Thanks again :peace:
RSVR
